BX GTi erratic idle!!!
cookingfat
Unread post by cookingfat »
Hi
Can anyone HELP? My GTi some times idles at 2000rpm, after hard acceleration, or hunts 1500 - 3000, occasionally revs to 4000 - 5000, <i>hairy</i> driving!!!
Often after a rest it will be normal, but occasionally it remains high when restarted.
Any help and advice will be greatly appreciated[:)]
AndersDK
Unread post by AndersDK »
A faulty (worn) throttle potientiometer is known to give this indication.
It's a flat device located at the end of the throttle flap axle.
What happens is that the resistive carbon track is worn down to the white plastic base by the slider - clearly seen when disassembled.
cookingfat
Thanks, Anders I'll check it at the weekend, sorry fro the delayed reply - been moving house!! Dave, St Helens, UK
