Hi can someone tell me where the egr valve is when looking from the front on the C5 mk1 2.2hdi estate please
have uploaded 2 pics looking from the front - the bottom two pics
http://g4jnw.weebly.com/c5.html
location of EGR valve on C5 2.2hdi
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: location of EGR valve on C5 2.2hdi
The thing with the blue connector on it is an Electrovalve, on my Xantia the blue means its controlling the EGR, follow the pipes coming off the thing and you should get to the EGR or the vacum pump.
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
I've got some pics of the egr, they don't show the location too well I'm afraid:
http://s75.photobucket.com/user/fredgis ... t=3&page=1
Are you just trying to disable it? If so then the easiest option is to get a blanking plate from ebay. Took me all of 10 mins to fit and I'm sure it improved response a little. I can find the seller if you want. I've removed the e/v, all the piping and blanked off that particular port to save possible vacuum leak sources. I can also look up which e/v it was as well ?
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
