engine oil
engine oil
have started to do a bit of servicing on my old bx diesel......i suspect that the oil hasn't been changed as it should because of 'suspect' servicing by someone else who should have done a good job...
drained all the old stuff out....new filter and 5w30 synthetic oil.........the intention is for it to act as a good flushing agent for a while....but don't know if i should just keep using it.......after all, synthetic oil has better load characteristics and is cleaner......any opinions?
Re: engine oil
i get my engine oil 'out of the back door' multi-fleet 5w30 synthetic for vauxhall vans, however i've just spent nearly 20 quid on semi synthetic 15w40 just in case.....
Re: engine oil
i remember not so long ago when i checked my oil when i got it home from a service and it looked quite black.......my man said that new oil goes black very quickly in a diesel..........however ....have checked my new oil after a few miles and i can still see transparency......with black staining in suspension....
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: engine oil
Oil in diesels does change colour very quickly.steviebx wrote:i remember not so long ago when i checked my oil when i got it home from a service and it looked quite black.......my man said that new oil goes black very quickly in a diesel..........however ....have checked my new oil after a few miles and i can still see transparency......with black staining in suspension....
Re: engine oil
But usually it takes a little longer than the drive home from a service.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
- x 31
Re: engine oil
I hope they gave the oil filter a little polish tooChlorate wrote:But usually it takes a little longer than the drive home from a service.
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2511
Re: engine oil
So are you saying you nick your oil from your employer but object to being ripped off yourself?steviebx wrote:i get my engine oil 'out of the back door' multi-fleet 5w30 synthetic for vauxhall vans, however i've just spent nearly 20 quid on semi synthetic 15w40 just in case.....
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1205
Re: engine oil
I use Comma semi synthetic in all my cars, costs about £13.00 from Trago Mills, use the cheapest oil you can find that is within spec and change it every 5,000 miles, your engine should last almost forever then.
- Diabolical
Re: engine oil
I have just changed oil in my C5 that I bought from main stealer, Total Quartz 9000 £29 that I thought was pretty good. However Sportif, Aylesbury are a bunch of pompous dickheads as the managed to also sell me incorrect filter £18 and wrong sized copper washer 99p.
First time changed oil in this car so I didn't see the difference until I went about it, so being a Sunday I had to hellfrauds to get correct ones.
I am going to give them some stick at Sportif tomorrow.
PS: Sportif at Chalfont Saint Giles are superb another 12 miles for me tho.
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
- My Cars: Rover 75 CDT TourerAuto , , Mercedes 190E 1.8 1993, 2CV6 Special 1987, Peugeot 206 1.1 2001. Repairs and maintenance of two Hyundai i10s
Deceased
Xantia TD Estate 1999 (now with Chris Morewood)
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
Renault Clio 1.4 Auto
GSA Pallas
Triumph Herald 1200 - x 3
Re: engine oil
On my Xantia TD I go for the cheapest 15W/40 oil in spec from the likes of Asda, Aldi or Lidl and change it and the filter every 4-5k miles. I got a bulk deal on filters - Purflux 1109's 10 for £12. Never had any problems and it uses no oil between changes (roughly every 4 months) I like new oil in for the Turbo mainly. Mine turns black within a hundred miles or so. I put it down to the residual oil still in the engine plus the usual diesel soot. Friend of mine just back with Ford Torneo - oil & filter "service" at the Ford Stealer - how much? £179!!! Told him about my £12.99 oil & £2 filter! - sick is not the word!! I can do my change in 10 minutes! Back from a run - select high. Switch of engine - take off cap - remove plug - let oil drain into receptacle. Whip off filter. While oil dripping out - fill filter with fresh oil. Refit plug. Finger over filter opening - spin on new filter. Refill to just under max mark. Done
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
Re: engine oil
6 months i change mine - 15w40 castrol gtx (book spec on the oil) - filter from carparts4less at £3 (also fuel filter). cant go wrong really
Simon
Re: engine oil
Ecp are doing a great offer on oil at the mo but be very quick, it's £12.50 for 5 litres so stock up
Re: engine oil
perhaps ...'out of the back door' was the wrong term........more of a perk.......always something left at the bottom of the barrel......Gibbo2286 wrote:So are you saying you nick your oil from your employer but object to being ripped off yourself?steviebx wrote:i get my engine oil 'out of the back door' multi-fleet 5w30 synthetic for vauxhall vans, however i've just spent nearly 20 quid on semi synthetic 15w40 just in case.....
