Engine shut down
Engine shut down
The engine will shut down while driving and when start again the RPM is not steady and tendency to shut down .it run perfectly after the second attempt . On and off the car want start and shows the key sign and eng. immobilizer. After several attempts manage to start. This hap pence after a long drive in hot condition
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Re: Engine shut down
What model / year ?
There may be a fault code stored if the light is on. Not aware of a Peugeot model with a 'immo' light on the dash though, they have it but its never normally wired up to anything.
It could be anything from an overheating ECU to an internal fault in the BSi, although the immobiliser should not even attempt to shut the car down when its running, its only normally checked on first switch on.
Andy.
its a pug 406, yom is Auto transmission 2000 . No fault codes recorded... But says....LAN communication fail in gear box ecu
- spider
- x 77
- Contact:
Its worth having the multiplugs off one at at time and inspecting them for corrosion etc, all the transmission ones anyway.
I seem to remember the gearbox ECU lives underneath the battery / battery box on these or on the side of it so its a bit vulnerable to a leaky battery, its worth checking its plug too.
Andy.
I have replaced all spark plugs, and Gear box ECU lies on the other side with engine ECU.
