Can I hand push the car while it's on LOW and the pump and LHM tank are disconnected?
Just have to move it in my garage due to bad weather about 15 meters. Will be LHM squirting out of the disconnected pipes while steering?
Thank you.
Moving car on LOW
xantos
- x 10
Moving car on LOW
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
addo
- Sara Watson's Stalker
- x 95
- x 94
Re: Moving car on LOW
it also depends how level the ground is you are moving the car over
Regards, malcolm.
KP
- x 27
Get some small coke bottles around any disconnected pipes and tape them on with some ductape. The time is well worth it compared to LHM stains on anything as they never come back out easily...
