citroen C5 1.6 Hdi lambda sensor location
White-Horse
Unread post by White-Horse »
Hi!
anybody know where can I find a lambda sensor on my car? I think it has got 2 sensors I find one of them, it is just before the DFP, but where is the second one?
Thanks!
x 94
Re: citroen C5 1.6 Hdi lambda sensor location
Unread post by citronut »
one will be forward and one behind the cat.
Regards, malcolm.
White-Horse
Thanks!
Mandrake
x 695
Unread post by Mandrake »
Lambda sensors on a diesel ? What is it measuring when the exhaust will always be lean ? (except at full throttle perhaps)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Lighty
x 34
Unread post by Lighty »
No lambda sensor on a 1.6hdi, just a cat temp sensor screwed into the air gap between the cat and the dpf .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
White-Horse
That's weird. I got problem with one of the exhaust sensor. I unplugged them and no extra error message. I checked the differential pressure sensor, it is looks okey. So somewhere one more sensor to check.
White-Horse
Ok! You win! Sorry! No lambda sensor!
Another question! Looks like the differential pressure sensor is wrong. I tried to measure it, but I'm not sure which one is signal cable. I measured 3 different voltage 1 pink wire 0.54V, White wire 0.05V, red wire 3.9V. The engine been turned off.
Are they good measures or not?
