Xantia II – Leaking front right caliper
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi All
I have a leak from my Xantia’s II front right caliper. Is this mainly because of a work caliper piston ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
citroenxm
Fallen Hero
x 70
Re: Xantia II – Leaking front right caliper
Unread post by citroenxm »
The Seal on the Brake piston could be worn. You could remove it from the car, pop the piston out the caliper and check the condition of the seal...
A very sad...
1994 XM 2.1 d auto
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Hi Paul, there is no real risk of corrosion in most of his climate, so it's more likely to be the O-ring seal at the handbrake input lever.
lancia58
(Donor 2022)
x 8
Hi Addo
Is there any post describing how to replace this O-ring ? can it be bought separately or the whole clipper repairing kit is needed ?
Zohar
