98 xantia td
modxl
98 xantia td
Unread post by modxl »
hi guys need a bit of help,my td conked out the over night,seems as if air getting in fuel system,ive changed all fuel pipe under bonnet starts but lumpy and smokey,tried running it out of a fuel can rigged up under bonnet still same primer bulb goes very soft,just notice that every no and again i get fuel injector light come on,shes got 168,000 on clock any ideas chaps
steve
xantia td
soon full leather
rear spoiler
isisalar
x 3
Re: 98 xantia td
Unread post by isisalar »
Most likely candidate is a white plastic gizmo on the side of the fuel filter, looks like a screw. It's something to do with heating the fuel in cold weather and is a well known weak point. You'll probably find diesel weeping from it if you pump the bulb. There's a lot about sealing this up in previous threads. As a get you going solution, sealing it up with blue tack worked for me!(for about a year) New filter body is best remedy or sealing it some other way. The difficulty is getting it clean enough to get anything to stick, but it is possible.
The leak is due to an o ring failing and these may be available from Citroen.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
modxl
Re: 98 xantia td
cheers paul ill give it a go,got spare filter body
regards steve
xantia td
soon full leather
rear spoiler
jgra1
(Donor 2021)
x 36
Re: 98 xantia td
Unread post by jgra1 »
change fuel filter Steve, too, while you are there..
if the fuel pressure drops off because of a blocked filter (esp if you have been running on anything other then diesel) you will get the light and so on
John
Xaccers
x 186
Re: 98 xantia td
Unread post by Xaccers »
If you replace the pipe from the bulb to the filter and then from the filter to the pump with clear silicone you'll be able to see any bubbles
DIY sphere tool
