Seat Wiring, 2002 going into 2005 need the wiring Diag
x 1994
Unread post by Stickyfinger »
Hi guys
Anybody got a wiring diagram from these cars ?
Putting Electric seats in the 2005 Car from a 2002
All movements/motors work as the plugs were a direct fit....Air Bags and Seat Tension ??....Plugs and wire different colours and shape :)
I Have THIS In-Car, the following connections/Blocks
Green Block...........Orange/Yellow/Black/Brown-White
Black Block (lrg)......Purple/Brown-Black
White Block...........Pink/Grey (other side)- Green/White
and
Black Block (sml).....Black/Black (other side)- Green/White (CD Changer >?)
Large CD Data connector
Seat Power Control Block
On the replacement Seats
Black Block (Square)..1st row----White/LightGreen/Orange/Brown/Grey
.........................2nd row....open/open/LightBlue/White/White
White/Yellow Block...............Orange/Yellow-Green/White/White
Cheers guys
Ben82
x 7
Re: Seat Wiring, 2002 going into 2005 need the wiring Diag
Unread post by Ben82 »
VINs for each car would probably help.. at least Models... I'm guessing C5s?
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
x 1994
Hiu
Yes...sorry...C5's
Into....2005 1.6tdi (110) C5 VTR
from
C5 2.2 hpi 2002 Excluv
x 1994
bump itee bump...
Still in need of the wiring diagrams....any thoughts ?
Ben82
x 7
Tried looking up the 2005 C5 last night, but seems like the wiring diagrams aren't working on it. There is a newer version of SEDRE available (11.2012), however I'm on limited bandwidth whilst in the uk, so won't be able to get it set up for at least a couple of weeks.
Maybe someone else might have the latest version and can look these up for you :)
Ben82
x 7
Right managed to get the latest SEDRE via other means :)
Here you go:
https://mega.co.nz/#F!p5t0hYCI!D_EVQ3GWxpdW51JZS79ifA" onclick="window.open(this.href);return false;
I used my 04 C5 as a template (aside from stating it's a RHD instead of LDH) for the Mk1 seats.. hence called 04. I don't think there will be any difference between the 02 and 04 seats though.
Documentation for reading PSA Wiring diagrams over here: http://peugeot.mainspot.net/wiringall/index.shtml" onclick="window.open(this.href);return false;
x 1994
Ben82.....that's fantastic ...thank you very much.
I have not looked fully, but do these have the Air-Bag wiring on or just the electric seats ?
Ben82
x 7
Hi, I've added the Seatbelts/Airbags diagrams to the folders :)
x 1994
5 Stars m8.....thank you
