Peugeot 406 estate HDI 2004 - heater motor
allanmc
Unread post by allanmc »
I seem to have another problem with the 406, I bought a new Blower Resistor for the fan and it fixed the fan running all the time but the Air Con. dosent work so I put my old unit back in to check if the A/C worked and it didnt, so can someone help with this pl;ease
Regards
Allan
Xantia 2.0i SX Auto, 1999
spider
x 77
Re: Peugeot 406 estate HDI 2004 - heater motor
Unread post by spider »
Can you hear the A/C clutch kick in ? , its a loud click even should be able to hear it above the engine noise (at idle) if you have a window open and are stationary.
There is gas in the AC yes ? , it won't work if the gas pressure is too low.
Andy.
allanmc
My Son said he charged the gas 2 years ago and that the A/C worked until the problem with the heater fan, if I can explain a bit more today he put a new module in and the fan seemed OK, just to be sure, he tried another module from another 406 and it was the same, so there is something wrong with the A/C
allan
spider
x 77
I think a diag on a Lexia (Planet in this case) would help, I think it may say if there's insufficient gas pressure I'm not sure. That would be my first idea to check, its not really safe to manually test for gas with a screwdriver etc (I have seen it done) plus if it was low it would be too low afterwards.
My initial thought though is if you cannot hear the compressor clutch going "clunk" then its likely the gas level is low as it has a pressure sensor fitted which shuts it off if its too low (or too high ie failed radiator fan)
Andy.
allanmc
There is no Clunk as you switch on the A/C. I have
allana Lexia only used it on Xantia not sure if it can be used on the Peugeot
spider
x 77
Its worth trying, Diagbox has Planet / Lexia.
It won't do it any harm to try at least as far as I know...
Andy.
