Hi all, meant to post this a while ago! When driving along normally I feel a slight dip in power as if the engine is braking, this only happens when you hear the FDV hiss, I presume this could be a load on the pump? Any suggestions as to whether this is normal, it's been doing it as far back as I can remember.
Cheers, Chris.
Xantia FDV hiss/power loss!
cc101
Xantia 1.9 TD 1993 (sinker)
Mandrake
- x 695
Re: Xantia FDV hiss/power loss!
The only sinker Xantia I've ever driven (1993 1.9TD) exhibited the same behaviour - a slight hiss from the FDV whenever the pressure regulator switched to "cut-in" mode to top up the pressure in the hydraulic system, and a significant dip in revs, at least at idle.
Whether its "normal" I can't say. The old single output 6 piston pumps in the sinkers draw a lot of horse power from the engine when the pressure regulator cuts in as you have 6 pistons supplying the pressure regulator.
On the later 6+2 pumps only 2 pistons supply the pressure regulator so the load increase is much smaller (1/3 as much) when the pressure regulator cuts in and is barely noticeable. I would say what you notice is just a quirk of the design in a sinker.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
cc101
Thanks Si, did the balljoints and driveshaft gaitors yesterday, my 5' scaffold pole came in handy!
Chris.
Chris.
