I have got side indicator plugs similar but there smaller with a 501 bulb. So I'm trying to find out where the bigger block name ones are?
thanks
Hello sorry I mean the plug on the right hand side with the 2 pins showing.spider wrote:Its a 382 bulb single filament 21W same as rear fogs etc. The smaller 501's are 4w or 5w. Amber ones (might have slightly different pin offset) are 382A or in some cases called 343, seems to vary on supplier which does not help.
The bulb holder comes like that as far as I know. I'm not sure what you're after ? , I had a similar problem with the side repeaters on the 106 the later ones had a different plug I ended up replacing them with the earlier types simply as they were available.
