Had a new enquiery yesterday from someone with a C5. His rear i thnk near side rear arm is cracking in operation so he had it up onca ramp and discivered metal fileings falling from it.. he went to my local garage. Anyway they reccomended he came to me to have any work done so i sugested a complete arm swap for another due to possible unit damage if its gone to far.
What sort of a job is an arm change on a c5 is it as good as a Xantia/Xm one? Has any one done a swap before.
I realise theres bearing kits but im concerened that the arm itsself could be damaged inside the bearing houses etc..
51 plate C5 Hdi rear arm swap
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
Re: 51 plate C5 Hdi rear arm swap
its much the same/as easy as the BX, CX, XANT, XM realy Paul,
though the C5 metal pivot spacer tube is shorter/does not come out to the face of the spacer bush's,
the spacer bush's have a recessed seat inside for the spacer tube,
i found you need to buy the bearings and seals from GSF and the spacer/pivot tube and spacer's from citroen,
all the parts in the usualy kit are not the same on C5's
there is a thread on C5 arm bearing way back were???? that i posted all the part price's, part No.'s and were i bought them from
hope this helps
hope this helps
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
I knew there be something, I went back 17 pages of posts last night and couldn't find anything obvious in Citroen section..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
i think you need a Steveeey ( migraine whoooooops i mean myglaren ) as im sure he found it last time i was searching for it
Regards, malcolm.
- x 5672
Found this that appears to be relevant Malcolm.
http://www.frenchcarforum.co.uk/forum/v ... 32&start=0" onclick="window.open(this.href);return false;
And here (Malcolm's link) http://www.frenchcarforum.co.uk/forum/v ... 04#p283404" onclick="window.open(this.href);return false;
- x 94
- Spoiler: show
Paul obviously its your choice to fit a new plastic arm liner,
o more often than not salvage the old one,
but i have loads of new ones from kits i have bought over the years
Regards, malcolm.
