will theses breaks fit my car
jacksun1987
will theses fir my 1.9td xantia 95 n reg
http://www.ebay.co.uk/itm/400257550366? ... 1438.l2649" onclick="window.open(this.href);return false;
there well cheap just what i needed if they work
Old-Guy
- x 24
Re: will theses breaks fit my car
The ebay vendor describes these discs as "283 x 27.5 mm" and to fit "Citroen Xantia 1.8, 1.9TD, 2.0, 2.0HDi, 2.0 Turbo and 2.1TD 1998 on" i.e Xantia II
Xantia S1 Discs:
Discs
FRONT (Ventilated)
266 x 20.4 (thick) is fitted to most hatchbacks.
283 x 22 should be fitted to estates and higher power hatchbacks.
288 x 28 S1 - only V6. S2 - HDi 110 & V6, plus 2.0 CT & 2.1 TD after RP 8001.
REAR (Solid)
224 x 9 Hatchbacks
251 x 12 Estates
There are tales of 1.8 petrol hatchbacks built with 283 discs and estates with 266s. As calipers and pads are different
for each size of disc, check before reaching the point of no return!!
The short answer is "Almost certainly NO".
Xantia S1 Discs:
Discs
FRONT (Ventilated)
REAR (Solid)
224 x 9 Hatchbacks
251 x 12 Estates
jacksun1987
ill be geting them right now just gotta be a bit carefull fOrm ebay buying parts. Knowing my luck they still wont fit lol
jacksun1987
Bugger just bought them
jacksun1987
not my day
jacksun1987
hynes manual says dem 266mm thinkness 20.4 mm
the breaks what im getting are 283 x 27.5 mm
qprdude
- x 14
jackson mate, can you not see the replies to your question?
Rick.
2013 Citroen DS 5 D/Sport
jacksun1987
i was getting ready to go out read the first one fast. Then thought ill have them. Came back read it all. Cocked up
When you are a bit striped for cash. You see theses so called bargains. Rush in dont think. Then bang you ve made a mistake.
Surly im not the only one
oneday
it says they do 14 day returns if you pay the postage. try to cancell before they post them or see if they have the correct ones
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
jacksun1987
ive sent them a message. I evern phoned up paypal. If you not happy or ask them to cancel. A item and they dont give you your money back. You can make a claim. Hopefully. They will see iee messed up. And cancel it
qprdude
- x 14
If the advert says clearly that the discs will fit your car and they don't,then they are surely not as described. As such, you would be entitled to back out of the deal. Just email the seller and tell him he has got it wrong and don't s
end the discs to you.
Rick.
qprdude
- x 14
Just read the advert and it looks like he has all the bases covered. You can only hope he agrees to cancel the deal. I would be very wary of his gear at that price anyway. Brakes are not something to scrimp on. If something seems too good to be true, it probably is.
Rick.
addo
- Sara Watson's Stalker
- x 95
jacksun1987
just asked him if he has got any 266mm ones see what happerns
jacksun1987
hopefully it be sorted. He says i should get a email from ebay that it will be canciled
