C5 air con
Danbuoy
C5 air con
Hi, I have a 58 reg C5 2.0 VTR, which was not cooling down inside at all. Took it to the garage who found it needed a new condenser. Sorted problem for just over a week, but yesterday and again today, despite the AC being set to "LO" the air coming out of the vents just doesn't feel very cold. It is slightly cool at best. I am wondering if the new condenser has failed, or whether it could be something else. Car is still under warranty (bought in March) so will probably ring the garage on Monday, but just thought I'd ask on here first!
Current car: Mar 13 to present: 58 Citroen C5 2.0 HDi VTR+
Past cars: Sept 05 - Mar 13: X reg Citroen Xantia 2.0 HDi LX - 160k and still apparently going strong!
Sept 03 - Sept 05: N reg Citroen ZX diesel RIP (died on A50 after an altercation with a Merc)
Robert12
Re: C5 air con
Mine is the same no air con 58 plate 2.2 HDI vtr+ going to take it back to dealers this morning will let you now wot they say
DickieG
- Monaco's youngest playboy
- x 38
Re: C5 air con
A common problem on these cars is failure of the low pressure pipe (large one) where it runs out of the compressor, on mine there was a very small pin hole located behind the heat bandage making it difficult to spot using a sniffer. If when the system was re-charged a dye was put into the system it should be quite easy to spot the leak using a UV torch and glasses.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
qprdude
- x 14
Re: C5 air con
Had my system checked and re gassed a week after buying because of the same problem. Air was cold, but not icy cold as a/c should be. Had no problems with it since then (July 1012)
Rick.
2013 Citroen DS 5 D/Sport
- x 3566
Re: C5 air con
The guy that came to fill my aircon after I replaced the condenser also said that the low pressure pipe was a common failure. I think he said that one problem was that they were too short and/or had too tight a radius so were normally replaced with slightly longer ones. I'm only going on what he said though.
Robert12
Re: C5 air con
Had mine regased this morning and all seems fine at the moment
