help needed please grand scenic parking brake
paulhelliwell2
hi all i have just bought a 55 reg grand scenic and the parking brake dosent work at all what could the problem be?
is it something i could fix or is it an expensive repair
thank you
thank you
SaabC5
Re: help needed please grand scenic parking brake
Wrong section Paul, this is Citroen not Renault section.
I do know about the Renault problem though because my friend is a Renault garage specialist. Two common problems with Scenics, electric handbrake and digital dash failures, both are subject to Renault recalls and they offer approx 80% of the costs towards the repairs in most cases. Get in touch with Renault UK customer relations and see what they offer.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
paulhelliwell2
thank you and sorry for posting in the wrong message board
steelcityuk
Can you provide more details? Is there a warning on the instrument panel, if so what does it say? Can you hear any 'action' at all when engaging or dis engaging the parking brake?
Steve.
Steve.
not applicable
paulhelliwell2
there is a warning on the dash saying parking brake fault it wont go on at all i have done the reset for the parking brake and you can here the motors but it still just makes a beep with the red light flashing
steelcityuk
I'd say there's two possibilities, either the main cable has snapped or it's become unhooked from the centre slider - that is what happened to my 04 plate. Unfortunately it's a tail up in the air on ramps kind of job.
not applicable
paulhelliwell2
is it easy to spot or are they cased in plastic and only visible on taking off? thank you
steelcityuk
I'm afraid it's a take it apart job. To get to mine it went like this. Put rear on ramps and chock wheels. Remove shield on 'axle', disconnect cables from the calipers, unthread cables, unbolt ecu/control unit and disconnect from the loom, jack up body of car slightly so that you can slide the 'centre mechanism' out to one side and remove it's plastic cover. If the main bowden cable from the ECU/control unit has come unhooked you're in luck if not then the chances are the main bowden cable has snapped in which case it's either a mortgage and take to Renault or see if a specialist can replace the bowden cable or scour the scrap yards. Chances are a Clip session or such will be needed to clear fault codes. Out of interest are the caliper springs still fitted?
Steve.
Steve.
not applicable
paulhelliwell2
i've got all that in the manual so i have pics to show what to do what are the calliper springs and where are they as there not mentioned in the book
could a totally dead battery of caused this fault? or someone pulling the emergency hand brake release?
paulhelliwell2
got it in pieces and the unit itself had some water in but the main problem is the cables have seized is there any way of getting some more or taking the plastic backing of to clean with wd40 and then getting some more plastic or something to reseal them with thanks
steelcityuk
It sounds as though your only choices are a replacement unit or see what speedycables can do for you.
Steve.
Steve.
not applicable
craig_s_b69
i could be wrong but i was told there is a release under the floor in the boot ??
like i say i haven't had a look just what i was told
Premira 1996
Rover Metro 1993
Nova old
Micra 1992
Micra 2003
Laguna 2000
Fiesta old
Fiesta old
Rover 25 1999
Micra 1998
c5 2.0 2003
Scenic ii 2005
Nissan Tiida 2009
Rover Metro 1993
Nova old
Micra 1992
Micra 2003
Laguna 2000
Fiesta old
Fiesta old
Rover 25 1999
Micra 1998
c5 2.0 2003
Scenic ii 2005
Nissan Tiida 2009
Lighty
- x 35
There is a yellow handle under the floor as a release. You need to get the car on Clip tbh, as the fault could be many things.
The cable & ECU part is not repairable, neither can you fit used, as it has the vin number coded in.
To my knowledge you can only fit a new virgin unit, (we replace loads).
You need to verify the fault 1st, and clip is the only way.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
paulhelliwell2
if the yellow handle has been pulled would that stop the hand brake coming on until it has been reset?
and yes you can put second hand part on as long as you get the right one
ie: automatic for auto and manual for clutch, it only needs programming for a virgin unit
