Tool time 2
Dave Bamber
Tool time 2
Unread post by Dave Bamber »
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing Genuine seats and door seals.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in the chassis just above the brake line that goes to the rear wheels.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your drink across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Shi...."
HYDRAULIC JACK: Used for lowering a BX to the ground after you have installed your new front disc pads, trapping the jack handle firmly under the front wing.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a BX upward off a hydraulic jack.
TWEEZERS: A tool for removing wood or wire splinters. See WIRE WHEEL.
PHONE: Tool for calling your neighbour to see if he has another hydraulic jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of earth straps and brake lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large engine mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
LEAD LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under European vehicles at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading but fairly accurate.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to hollow out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Machine Mart Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Paris, and rounds them off.
PRY BAR: A tool used to crumple the metal surrounding that £40 clip or bracket you needed to remove in order to replace a 10 bob part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short
Happy days..........[:o)]
bxbodger
Unread post by bxbodger »
I would add to the above list the MIG-WELDER; very useful for making holes in your car, and then making these same holes actually bigger whilst simultaneeously attempting to make them smaller again....much quicker and a lot more effective than the boring old drill.
puddle jumper
Unread post by puddle jumper »
I would like to add the Mole grip to the list. A device that's pounds per sq.inch grip at one end is at least equal if not greater to the surface area of the blood blister produced by the handle at the other
ghostrider
Unread post by ghostrider »
and I thought Mole grips were knuckle removers :-))
________
Extreme q vaporizer
