Dispatch 2004 2.0HDI cutting out
Morjen
Unread post by Morjen »
Just wondered if someone can help.
my Van cuts out intermittantly with no DTC codes logged.
It cuts out on tickover right up to motorway speeds but allways restarts (sometimes quicker than others).
I have checked looms and fuse box under bonnet for damage/corrosion all ok.
I have changed the large maroon relay but the fault still is preasant.
Regards
Jim. :?:
Morjen
Re: Dispatch 2004 2.0HDI cutting out
Have managed to sort out fault now traced and repaired fault with very little cost.
Think main dealer would of had a field day with my wallet.
JIM
x 3306
Well done, Jim. What was the problem (in case anybody else has a similar issue)?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I had a cutting out issue but only when useing a heavy foot or high fuel demands..
Mine was the engine fuel pump... not the tank one.
So what was your fault Jim...
A very sad...
1994 XM 2.1 d auto
Morjen
I traced the fault using this forum. I Found the engine loom wires just behind the oil cooler had rubbed through and gone green causing a high resistance. there was no damage to the tracking that was meant to keep the looms in tip top condition. a few heat shrink connectors and job done.
