New thread for a new problem!! Followed the red wire back from the blower motor, behind the airbag.. locking type connector with large beige wire heading off in the general direction of the fuse box...
Stop press.. just got a wiring diagram from Autodata showing the supplies... I am still interested in other peoples experiences in this area!!
Problem solved.... battery terminal problem!!!! Poor supply. Almost everything else worked fine
Xantia HDi 2.0 aircon blower motor wiring info..please!!
DeafOldFart
Just because you can't see it, don't mean it ain't there..... if it floats, flies or fornicates ,you are better off renting
