1997 Laguna estate sagging rear suspension
RussellF97
x 10
Unread post by RussellF97 »
Hi All,
A friend of mine down in the Charente has a Laguna estate and the back end is lower than normal. The car is 300 miles away (I'm in Brittany) but I believe that it's a torsion bar setup; if it is, is adjustment a DIY job or should I tell her to take it in to her friendly neighbourhood garage bloke?
Thanks for any advice,
Phil 8-)
Phil
Indecision is the key to flexibility...
Lighty
x 34
Re: 1997 Laguna estate sagging rear suspension
Unread post by Lighty »
Definitely not a DIY job !
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
RussellF97
x 10
Hi Lighty,
Many thanks for your reply. I had a feeling that might be the case, but is there any specific reason I should leave well alone, such as special tools required, etc.
Cheers,
Phil 8-)
Phil
Lighty
x 34
Not sure that I have specifically done a Laguna of that era, but the torsion bars are always seized solid due to age, and a hot spanner/ big hammer is usually the order of the day.
Citroen C15
Citroen Ami
RussellF97
x 10
OK Lighty, thanks for getting back to me. It doesn't sound the sort of job to be doing lying on your back with the car on axle stands then!
Phil
