It appears the pressure sensor is integral to the ABS block. I can't get a pressure reading on the system; the pedal switch is new and works.
Lots of internet discussion of fixes, but the turnaround time to Australia is what gets me - So I'm wondering if the wiring can be spliced to use an external sensor brazed into one of the infeed lines.
Also - is this failure caused by winding back calipers without cracking the bleed screw?
C2 ABS Pressure Sensor Failure - What Fails?
addo
- Sara Watson's Stalker
- x 95
