peugeot 2004 406 HDI
allanmc
Unread post by allanmc »
Hope someone can help, the heater fan on my sons car runs at fool speed when you start the car, on my Xantia there is a Module with 2 transisters which I have replaced a couple of times but the Peugeot is different can some one help please.
Rgards
Allan
Xantia 2.0i SX Auto, 1999
x 1240
Re: peugeot 2004 406 HDI
Unread post by Peter.N. »
Can't help a lot as mine hasn't gone wrong - yet. According to the book it has a separate 'control module' although separate connections are not shown as if its part of the motor assembly. Does it have climate control, is it an LX or GLX?
allanmc
The car has Climate Control and is a GLS I am sure there will be a Module some place and someone will tell me
allan
x 94
Unread post by citronut »
have you got the fan/motor out yet, as it might be similar to the 307, this has an electronic speed controller attached in the same place as the XANTS with the large transistors,
if you send me the last 8 digits of your chassis/VIN No. i will look on pug service box
Regards, malcolm.
allanmc
We have the fan motor out and it is entirely different to the Xantia, this is the last 8 numbers of the vin no 81657641, hope you can help
regards
Allan
Gibbo_Wirral
Unread post by Gibbo_Wirral »
I had this on my 307. It turned out to be the relays under the bonnet slam panel.
Took them out and cleaned them and all was well. There was obviously an issue where a current was getting through to activate it but not to switch it off again.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
x 94
here is price and part No. for the speed control module
Reference Description Quantity Price - VAT Price + VAT Total + VAT Selection
6441L2 CONTROL MODULE 86.01 GBP 103.21 GBP 103.21 GBP
here are a couple of ebay listings
http://www.ebay.co.uk/itm/PEUGEOT-1007- ... 0805938162" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/6441L2-Peugeo ... 0916236172" onclick="window.open(this.href);return false;
it looks like i fits into the bottom of the evaporator housing just behind the center consul
Regards, malcolm.
allanmc
sorry but where is the bonnet slam panel
x 94
the bonnet slam panel is the bit the bonnet shuts/locks onto
Regards, malcolm.
