Citroen Dispatch 2000 HELP!!
I have a 2000 Citroen Dispatch 1.9 disel non turbo van that has a problem!! For no reason and at very spaced intervals it will just cut out! I have changed fuel filter,air filter and removed the injectors and had them professionally tested ( they are fine) i am out of idears! it does smoke (white) on start up from cold and runs slightly rough on tick over but once warm all is well! You can be driving at say 50 on a straight road in 5 th gear it will just pause then stop!? once at a halt it will start fine it is a worry as i am going on holiday in it with the family soon!! Any help would be great! Thanks Jason
Citroen Despatch Help!!
Stewart(oily)
- x 35
Re: Citroën Despatch Help!!
I would be checking the battery cables at both ends to begin with.
Richard_C
- (Donor 2026)
- x 228
I would be looking at electrical, battery cables as suggested or earthing points corroded. My old BX had a similar problem and it turned out to be the lead (indirectly) from ignition switch to the fuel pump, the one which tells the thing to stop when you switch off, worn and shorting out where it goes through the bulkhead. I had spent ages looking for a mechanical fault and it turned out to be electrical and simple.
Richard_C
- x 1056
Take a close look at the wiring loom that runs over the top of the steering pump, you will need to take off the clips & pull back the plastic conduit, very common for several wires to rot & break in there.
