Xantia front corrector
c.morewood
x 55
Re: Xantia front corrector
Unread post by c.morewood »
It looks complicated, but in reality its quite simple and well worth doing. Just be sure and get the captive spanner as stated in the thread and be careful not to round off the nuts and also mark one of the pair of pipes which feed the height corrector.. its all to easy to get them mixed up, as I found out.
The cradle is only held on with 2 bolts and the Height corrector spring/rod.. its a bit of a pain to wiggle it out as it'll only come out one way and go in the same way.
Just follow the guide and you'll have no problems.
Good luck Mike.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
IF you do seperate the corrector from the cradle pay SERIOUS ATTENTION to the position of the levers in the correct places in the correctors "arm" .. get it wrong and you will be chasing height issues for ages.. its is specific!!
Personally id remove the three high pressure pipes and the return and mark them somehow and remove the whole lot so you can look at it closer..
A very sad...
1994 XM 2.1 d auto
Old-Guy
x 24
Unread post by Old-Guy »
citroenxm wrote:IF you do seperate the corrector from the cradle pay SERIOUS ATTENTION to the position of the levers in the correct places in the correctors "arm" .. get it wrong and you will be chasing height issues for ages.. its is specific!!
This is what digital cameras are for - "a picture is worth a thousand words" :)
As my memory's not what it was, I've tried to get into the habit (but don't always remember :roll:) of taking photos before and during dis-assembly to avoid wasting time (or worse) when re-assembling. I also make notes for next time: what I should do differently next time, tricks on how to undo/remove..., tools and parts needed.
Now what was I doing?
Mandrake
x 694
Unread post by Mandrake »
Thumbs up on the digital camera. :)
I use the camera in my phone to take photos of pipes/wiring etc before disassembly, that way if reassembly is not obvious (especially if done a few days later) I can refer to the pictures. A great time saver!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 94
Unread post by citronut »
superloopy wrote: Malcom (citronut) always posts that the height corrector itself need not come off to do this. If so, how does the cradle itself detach? Is it as easy just to remove everything including the height corrector itself?
quite the opposite actually,
although it can be a good idea to strip, clean and re/assemble the H/C itself whilst your there,
so in a way i agree with Paul
Regards, malcolm.
Old-Guy
x 24
Depends on how much of a glutton for punishment (perfectionist) you are. Me? "If it ain't broke, don't fix it".
x 94
if you wish to leave the H/C in situe undo the two 11mm bolts ( spanner size ) which go through the cradle into the H/C,
then once the cradle is unbolted as Paul say make 200% sure you know how the linkage hooks back into the H/C and linkage/height lever rods on the car
Regards, malcolm.
