Peugeot 206 cc faulty door sensor
bojan206cc
Hello to everybody on this forum.
I have Peugeot 206 cc 1.6 from 2003. I have problem with passenger door. When i close the door indicator gives me a signal that the door is still open. When i press the remote lock on the key, the car locks and immediately unlocks. if anyone has a solution for this problem please tell me, or somebody know Is it possible to turn off this sensor. This problem going on my nerves
- x 3275
Re: Peugeot 206 cc faulty door sensor
I cannot promise that this is the right answer, but if a wire has failed (normally in the concertina sleeve between the door and pillar) then the central locking might not be able to see the lock status of the door. I had a (slightly) similar issue in that (on both nearside and offside) rear doors were no longer on the central locking, and this wasn't able to monitor (or activate) them. Some time with a soldering iron and extra lengths of wiring overcame this problem.
PS Welcome to the forum. Have fun, and happy spannering.
bojan206cc
Thanks for your advice but i think that it is not the problem. The problem is the door sensor who is located in the lock. Sometimes works sometimes not. I wonder if anyone has solution for this problem or if there is a chance to turn off the sensor.
spider
- x 77
I think they don't have a door pin switch they rely on the actuator itself, that may be faulty. It may be easier if the door wiring is OK (I think Planet can do an actuator test too) to replace the actuator in the door.
Andy.
