Xantia bottom ball joints
Mandrake
- x 695
Re: Xantia bottom ball joints
I bought a pair of Lemforders for mine, but didn't get around to fitting either of them yet as for some reason it passed last time without a comment! I might not be so lucky this time, (tomorrow) but we'll see...(like you, I'm not going to tackle the job myself if they need doing...)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
addo
- Sara Watson's Stalker
- x 95
- x 1489
Drop link has to come off, as it's in the way AFAIK. If the BJ is otherwise OK, it should be possible to fit a new dust shield (which you are right are now a fail if split).
addo
- x 95
jgra1
- (Donor 2021)
- x 36
Mike are you talking the metal heat shield, or the rubber dust boot?
The boot should fail if split, the heat shield shouldn't matter at all..,
John
John
- x 1489
I was talking about the rubber bit - which MOT refers to as dust cover, eg "a ball joint dust cover missing or excessively damaged, deteriorated or insecure to the extent that it would no longer prevent the ingress of dirt etc.".
Should be possible to do the boot in situ and will need less dismantling than changing the joint - although a garage with a windy gun and the right tool should be able to whizz it out.
addo
- x 95
red_dwarfers
- x 58
The dust covers are cheaply available on eBay. Robert Smart (username escapes me!) Had a link up on here a few months back.
Kev
'19 C4 Cactus 130 Flair
- x 1489
Loads, as noted, on e-bay You need to know what size, maybe Mandrake who's got some on the shelf can measure the top and bottom diameters....
jgra1
- (Donor 2021)
- x 36
yes agree, went to factors recently for a boot.. they are just generic sizes.. factors, I think, would only sell me a pack of six and I didnt have the size to hand.. but yep, can get a handful cheaply if you want
addo
- x 95
addo
- x 95
addo
- x 95
addo
- x 95
