Relay morette headlamps
Welshy_Pete
Unread post by Welshy_Pete »
There a relay on the passenger side morette headlamps there all connected up the wiring. But apart from the red and black wire.
So I'm wandering were do the red and black wire go?
There going on a ph3 306 hdi thanks
Deanxm
x 87
Re: Relay morette headlamps
Unread post by Deanxm »
Red to fused 30A positive supply, black to ground.
These two wires supply current to the high beam lamps and use the existing switched feed as a trigger for the relay.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Welshy_Pete
Deanxm wrote:Red to fused 30A positive supply, black to ground.
D
Hello thanks for the information.
So I can join the red wire to a already used 30a or put in a empty spare one?
