Hi all, I'm looking for the part number on my xant hydraulic pump and fdv valve, I can see a number on the end of the pump which is 09273A but can't see any parts on citroen.service relating to this number, any help much appreciated.
Chris.
Part number query
- x 94
Re: Part number query
did you enter you chassis/VIN No. into the top left VIN box,
as this will bring up just parts related to your specific car
Regards, malcolm.
cc101
Hi Malc, yes I put the vin in but the part number is totally different, starts with a seven if I remember. Are the numbers that are printed on the parts the same as what citroen service says. I know the pump is not the original as it has a 'void if removed' sticker on it.
Xantia 1.9 TD 1993 (sinker)
Mandrake
- x 695
What's happened to your pump ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 94
if you send me the last 8 digits of your chassis/VIN No. i will have a look to see what i think
and yes the part No.'s are what is on the packet as service citroen is the dealers look up data base
Regards, malcolm.
cc101
