Xantia 94-1.9TD. Situation: When starting the engine the stop light goes of after a few seconds (normal). But when driving away it takes about a kilometer before the suspension finally becomes soft(before car rises). When driving the absorbers are perfect so no problem om the spheres I think.
What can I do to get the pressure on faster? (replace something?)
Even if I keep the engine running for half a minute before driving away doesn't help..
Rising of xantia
blueboy2001
If theres sufficient LHM in the tank, then the problem is more than likely the pump is becoming slow with age. Temperature also plays a part, I've noticed mine rises slower in the cold weather.
Really theres not a lot you can do other than replace the pump, which is not cheap. You will find it will rise a lot quicker if you rev it to 2000 RPM for 10 seconds shortly after starting.
jeremy
AndersDK
Hans
