20l hdi is the a/c pressure swith in the throttle circuit
wrighty
ecu repaired by bba reman ,new throttle pot fitted ,stil in limp mode with po225 code is a/c pressure switch in the same circuit please help day 9 off road as ataxi
citroenxm
- Fallen Hero
- x 70
Re: 20l hdi is the a/c pressure swith in the throttle circui
Whats the Car, we have NO Chance of offering help without telling us what car you are refering to!!?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
wrighty
xsara picasso 2.0l hdi manual
citroenxm
- Fallen Hero
- x 70
Have you had the car back on the Diagnostic computer to RESET all faults after refitting repaird computer..
I dont think the pressure switch is on the throttle, though Im not familliar with Picassos. How old is the Pic?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
wrighty
the car is a 2005 registersd ,yes been back on diagnotics p0225 allways there as throttle circuit 2 failure ,the only tine we can clear the code is with ignition on and a/c pressure switch diconected,any other time with all connections on and engine running the car is in limp mode reading p0225 ,we have a wave form from throttle pot via e c u ,so we know this is ok.ac switch is a 3 pin ,off the car and using ohm meter the only reading is between pins 2&3 ,reading of 42.6 ohms all other combonstions no reading at all
