I have a Citroen ZX 1.9D done 90K
I want to chg timing belt, Do i have to chg 2 timing baring want i chg timing belt.
Timing Belt & Baring
- x 1504
When you change the belt, check the rollers on the tensioner and the idler for roughness and / or play - replace if you think necessary. These are not a known weak point on these engines, and mostly last the life of the engine, but some people replace them precautionarily at about 120,000 miles. Don't forget to check the water pump for signs of leaking / play as well!
Richard
Richard
JohnD
- x 72
tomsheppard
