where to buy a lexia?
john
wheres the best place to buy this? any links also gratefully received
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Ben82
- x 7
Re: where to buy a lexia?
http://www.frenchcarforum.co.uk/forum/v ... 46#p370980" onclick="window.open(this.href);return false;
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Chlorate
Quite a few on eBay too, although I've heard they can be mined with Chinese knock-offs.
One thing to point out is that the software (Diagbox) is available for free on the internet. Never pay for Diagbox, it seems that every copy you can buy is bootlegged anyway since you have to go through a number of workarounds to keep it from talking to PSA.
If you want a legitimate copy, you'll have to ask PSA and methinks they won't sell it to us mere mortals. At least not for a reasonable price.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
handyman
You're dead right there, Chlorate. Any link or download with Lexia software to PSA on the internet and they will block the software, rendering it useless.
PSA wont release any diagnostic software to anybody outside of their dealer network, even though much of the early stuff is now obsolete, in their terms. They're not interested in keeping older Citroens or other PSA models on the road.
H
H
- x 2941
I believe you can actually buy the approved software from Citroen, there is a part number for it in the catalogue but it's priced in the region of £300+handyman wrote:You're dead right there, Chlorate. Any link or download with Lexia software to PSA on the internet and they will block the software, rendering it useless.
PSA wont release any diagnostic software to anybody outside of their dealer network, even though much of the early stuff is now obsolete, in their terms. They're not interested in keeping older Citroëns or other PSA models on the road.
H
Ben82
- x 7
Just to clarify, all non-genuine lexias are Chinese Clones. But there are differences in build quality depending on what factory they have come out of.Chlorate wrote:Quite a few on eBay too, although I've heard they can be mined with Chinese knock-offs.
john
well it arrived today, quite a few leads eh? not quite sure what i need or where they go but i'll hopefully get it sorted.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Ben82
- x 7
USB to laptop (short or long one), the D15 pin goes in the device, the other end of the OBD cable goes in the big round socket of the device. If the car has an OBD socket then the rest of the cables can be ignored.john wrote:well it arrived today, quite a few leads eh? not quite sure what i need or where they go but i'll hopefully get it sorted.
Chlorate
What do the rest of the cables actually do anyway?
previously:
previously:
john
ah, gotcha, it came with 3 discs,Ben82 wrote:USB to laptop (short or long one), the D15 pin goes in the device, the other end of the OBD cable goes in the big round socket of the device. If the car has an OBD socket then the rest of the cables can be ignored.john wrote:well it arrived today, quite a few leads eh? not quite sure what i need or where they go but i'll hopefully get it sorted.
disc1 digibo 6.01 & digibox 7.04
disc2 pp2000
disc3 with no writing on it, it does however have a label stuck on it
this is gona be complicated isn't it
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Ben82
- x 7
This might be easier to follow
(The bits using UltraISO are essentially a DVD Drive Emulator, so since you have the physical disc you can ignore them and use the 7.01 disc).
If the discs are a bit confusing you can grab the 7.02 iso from Simon's share here: mega.co.nz/#F!jJJ11IhI!Kr2p1iBUR4oxVw_oDec_bA and use that (along with the UltraISO steps).
Chlorate
Use Mandrake's link to the software, it has updates to newer versions and is much simpler to install.
Also, absolutely positively ensure that your computer is not connected to the internet when you are using Diagbox, I had trouble with mine talking to PSA and getting itself deactivated
It does however need to detect some networking hardware available so the Sim application can work. (i.e. disconnect from wireless networks or unplug LAN cable).
previously:
previously:
Mandrake
- x 695
The large D shaped connector that goes to the round connector which plugs into the interface is a standard 16 pin OBD2 connector used by Xantia Mk2 and all later Citroens, the long rectangular connector is a proprietary 30 pin connector used on Mk1 Xantias and possibly other Citroens of the same vintage (XM ?) while the two pin prong is for even older models such as BX, AX, ZX etc...Chlorate wrote:What do the rest of the cables actually do anyway?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Mandrake
- x 695
It looks like his discs included the same version of 7.01/7.02 as my download link, so I would start there to save downloading. The updates can be downloaded from my link though.Chlorate wrote:Use Mandrake's link to the software, it has updates to newer versions and is much simpler to install.
You must be allowing Diagbox to run an "Internet update", this will cause the activation to be lost. Make sure you always say no when it says check for updates and you should be fine. I no longer bother to disconnect the Internet connection on mine when I use it and I have no problems.Also, absolutely positively ensure that your computer is not connected to the internet when you are using Diagbox, I had trouble with mine talking to PSA and getting itself deactivated![]()
Simon
1978 CX 2400
1978 CX 2400
john
so,i managed to install 7.01, closed the program then ran it again, it said it was updating but it fails to do so, ive tried it 2 or 3 times now and it appears to run to the end then gives the error
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
