HOWTO: Retrofitting MK1 C5 Cruise Control
x 8469
We are deeply indebted to Wheeler for taking the time and trouble to write the attached PDF document detailing the steps necessary to retrofit cruise control to a MK1 C5... This is an oft-asked question and now the steps and Lexia work necessary are very clearly described.
Retrofitting MK1 C5 Cruise Control - PDF Document
This is a big picture-heavy document and may take a while to download...
I have posted it here initially and will in due course move it to the appropriate area of the forum.
Wheeler - many thanks indeed :)
citroenxm
Fallen Hero
x 70
Re: HOWTO: Retrofitting MK1 C5 Cruise Control
Unread post by citroenxm »
I would like to see this on S1.5 C5 models too. (Ones with C4 headlights)
Why not just buy a VTX C5, they have cruise as standard along with Exclusive and Exclusive SE models.. :-D
I helpfull document which I might need one day when I accidentally buy a Mk.1 C5
A very sad...
1994 XM 2.1 d auto
411514
(Donor 2017)
x 39
Unread post by 411514 »
Excellent guide, many thanks Wheeler.
Sam
2003 C5 2.0HDI 110
Citroenmad
x 110
Unread post by Citroenmad »
citroenxm wrote:I would like to see this on S1.5 C5 models too. (Ones with C4 headlights)
Only the LX and Design C5 facelifts do without cruise control, its standard on VTR, VTX and Exclusive.
I suspect the theory is much the same, only with the other stalk which has cruise and speed limiter functions.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1061
Unread post by wheeler »
I've never done it on a mk 2 but yes I would imagine its an almost identical procedure. The only other different thing is the accelerator pedal has a 'hard spot' switch on it for overriding the speed limiter function if you floor the pedal hard in an emergency. So you would also need to replace the pedal but I don't know if the extra
wiring for it is present or not.
citroenxm
Fallen Hero
x 70
Ahhhhh the s2 im sure has that "Hard" bit im sure.. ill double check mums design again next time im there..
A very sad...
1994 XM 2.1 d auto
10mbc
x 90
Unread post by 10mbc »
Does any information appear on C5 1 anywhere on any display that the cruise control is active? I have retrofitted mine and works well but there is no visual confirmation. I am not sure if this is by design or there is another step to enable this.
x 1061
No, there is no visual or audible inducation that the CC is enabled or what speed it is set to on the mk1.
