information on c5 2008-> headlights
josmif
New User
Unread post by josmif »
Hi I would like some information my 2008 c5(X7) exclusive has halogen type headlamps
with cornering lights also and auto levelling, I decided to change for OEM xenon type
headlights and I wanted ask if someone can help me in this transition.
Are they a direct fit plug and play, is there any instructions to give to the ecu in regards of this change?
I will appreciate all help
thanks
new owner of 2005 c5
qprdude
x 14
Re: information on c5 2008-> headlights
Unread post by qprdude »
Not sure how easy it is, but if you have Hydractive suspension, the whole car acts as the leveller I'm told.
Couldn't be sure, but I think you will need headlamp washers if you change to Xenon. There's also something about the lens being different from Halogen lights. Future MOT 's might be a problem.
Rick.
2013 Citroen DS 5 D/Sport
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
qprdude wrote: Couldn't be sure, but I think you will need headlamp washers if you change to Xenon.
That's right! The headlight washer system needs to work when the xenons are lit.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
josmif
New User
But what you mean without headlight washers cant have xenons,,
I see loads of cars with factory xenons and no washer jets
qprdude
x 14
josmif wrote:But what you mean without headlight washers cant have xenons,,
Not factory ones you don't. Certainly originals, but fitted after, and as the law stands they must have washers I believe . My son's BMW failed the MOT because Xenons had been fitted and it didn't have washers. They said the lens should be different as well.
From the current MOT test.
Lighting.
Headlamps. Vehicles fitted with High Intensity Discharge (HID) and LED light sources will have a new reason for rejection, "A mandatory headlamp levelling or cleaning device missing, inoperative or otherwise obviously defective."
Rick.
