Airbag light came on as on roundabout.
idkdelta45
Unread post by idkdelta45 »
Wondering if anyone can advise me what to do next please. Airbag light came on as driving at 20mph ish,on a roundabout. Took it to have it plugged in to diagnostic machine and it said p1801 drivers airbag igniter circuit open. Mechanic was busy said I could leave it and someone would play with it when they had time but its a taxi and if they couldnt give me a definite time etc,I aint leaving it,sorry. So any of you kind magicians got any idea what to try? Thanks in advance.
lankytim
Re: Airbag light came on as on roundabout.
Unread post by lankytim »
It's probably a dodgy airbag connection under the drivers or passenger seat. Just unplug it and make sure it's making a good connection. Often just waggling it around will fix the issue.
Mandrake
x 695
Unread post by Mandrake »
It would be useful to know what car it is... ;)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
idkdelta45
Sorry,citroen picasso 2.0 hdi (53 plate,2004). Tried messing with green plug,passenger side,no change,can not locate any plug on drivers side! Thanks ppl.
x 1056
Unread post by wheeler »
The plugs under the seats generally don't cause any problems on the picassos as the per tensioners are in the reels not the stalks. With that fault code the chances are its the rotary connector behind the steering wheel at fault but would need more checks to confirm.
idkdelta45
Thanks. Any idea if they are easy to get hold of,scrapyard,or are they a pain in the buttocks?
x 1056
On a 2004 model it will be part of the com2000 unit which also has the indicator & wiper stalks. They are quite expensive brand new but easy enough to change. you can use a 2nd hand ones no problem.
x 2938
wheeler wrote:On a 2004 model it will be part of the com2000 unit which also has the indicator & wiper stalks. They are quite expensive brand new but easy enough to change. you can use a 2nd hand ones no problem.
Nineteen different variations of that across the range so you need to be sure it's the right one.
x 3298
The best thing you could do at this point is to post up the last 8 digits of the VIN number, so that somebody who knows what they are doing (not I, sorry!) can then look up the configuration, and let you know the factory configuration (which ECUs, etc.).
