Berlingo 1.9d 2004
Hi all, I have a 2004 Citroen Berlingo with a Delphi diesel pump R84 48B391C / 105087EXF / DPCDWLP12. It has a seal that has gone and I've managed to get another used fuel pump to fit and replace but where could I purchase overhaul seals to repair the original.
Regards
Steve
Diesel Pump Replacement Seals
- x 94
Re: Diesel Pump Replacement Seals
if its the usual leak on the Lucas/Delphi pump at the throttle spindle, you sometimes need to fit a new lid as well,
you can fit the spindle seals in situe without going to all the time and trouble of removing the pump,
very easy job
because when the seals fail the spindle can wear into the lid,
this company can supply the parts,
http://www.merlindiesel.com/" onclick="window.open(this.href);return false;
when ordering from this company mind you order all you need in one shot as there carriage can be a bit steep otherwise
very easy job
Regards, malcolm.
