power streering pipe
Robert12
Citroen c5 hdi 2.0 2004 any one now where to get the power steering pipe the one from pump to rack, as spoke to main deelers and there saying its two peece pipe £272 ouch
lankytim
Re: power streering pipe
Can't you get someone like pirtek to make one up? If you take in your old one they should be able to help.
- x 5674
Try giving Martin at Pleiades a ring. He will most likely be able to help and has a mail order option if you have difficulty getting to him.
Clogzz
- x 40
Re: power steering pipe
The pipe assembly that needs replacing can be separated from the one running along the bottom of the radiator.
It's a big job that needs lifting of the transmission.
£272 is cheap, here it's $920.
