starter problem.
john
starter problem.
Unread post by john »
problem is sometimes it just spins and doesn't turn the car over, I have removed it and tested as follows.
earthed the motor body, put the positive to the small bolt (bottom 1 on the pic) and both the solenoid and starter spin as expected.
when I put the + to the big 1 on the left it does nothing, surely it meant to so something or is that another earth?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 1056
Re: starter problem.
Unread post by wheeler »
The big terminal on the left is the main battery positive feed, it is normally permanently live straight of the battery but it wont do anything until the small terminal is energised as well.
Earthing the casing & powering just the small terminal should make the solenoid jump out but im surprised the starter actually spins ? Would normally need the big one on the left live & the small bottom one powered up at the same time.
Xantidote
x 5
Unread post by Xantidote »
wheeler wrote:Earthing the casing & powering just the small terminal should make the solenoid jump out but im surprised the starter actually spins ? Would normally need the big one on the left live & the small bottom one powered up at the same time.
My thoughts exactly
Martin
1995 Xantia TDLX (deceased :( )
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It sounds ominously like a dead ring gear.
john
mmm, definately spins and pops out the ring/cog thing.
looks like a new starter then.
Subaru Impreza WRX
Nissan Primastar
Old-Guy
x 24
Unread post by Old-Guy »
john wrote:mmm, definately spins and pops out the ring/cog thing.
No! What you describe is a starter in good working order, unless the starter pinion isn't being pushed the full length of the shaft. While the starter's out, and before you carefully refit it, check the ring gear on the flywheel - the toothed ring that the "ring/cog thing" engages with. If it's badly chewed or there's a gap in the teeth, the starter can't get a grip. In this situation, it's often possible to start the car by rocking it in top gear so that the engine is slightly rotated giving the starter a 'good' section of ring gear to start on.
john
i'll get a pic of the teeth,
Subaru Impreza WRX
Nissan Primastar
john
ok i didnt read the above post properlly, i read it as pics of the cogs on the starter #-o
here's the motor
will try and get pics of the fly wheel later, not sure how easy it will be with limited access.
Subaru Impreza WRX
Nissan Primastar
x 1240
Unread post by Peter.N. »
When you connect the starter does the pinion go right to the end of the shaft?
john
Peter.N. wrote:When you connect the starter does the pinion go right to the end of the shaft?
yes.
Subaru Impreza WRX
Nissan Primastar
x 1459
Unread post by xantia_v6 »
It looks very oily. I suspect that oil has got into the one-way clutch and it is slipping.
Sometimes a good wash with a degreasant will help, sometimes (if the clutch is worn) it wont.
john
xantia_v6 wrote:It looks very oily. I suspect that oil has got into the one-way clutch and it is slipping.
if i wash it do i not run the risk if totally knackering it?
Subaru Impreza WRX
Nissan Primastar
john
Old-Guy wrote: check the ring gear on the flywheel - the toothed ring that the "ring/cog thing" engages with. If it's badly chewed or there's a gap in the teeth, the starter can't get a grip.
hows that look?
Subaru Impreza WRX
Nissan Primastar
x 1240
Looks as though the pinion is not fully engaging with the flywheel, you shouldn't get worn teeth with a pre engaged starter. Theorectically the starter shouldn't be able to rotate until the pinion is fully engaged as the motor contacts don't close until that point, so it would seem that something is awry with your starter.
addo
x 95
You can see there is good (normal) engagement by the wear marks upon the pinion. I'd like to see the flywheel rotated completely, as I suspect there is a pocket of intense wear which is bringing about the condition.
