Hi My Xantia 1.8 estate 1.6v petrol year 2000 on an X plate has developed a hydraulic leak at the rear. I have put it on ramps and had a good look and can not see where the leak is coming from. The height corrector was changed about 6 months ago and some pipes were also replaced. I have checked all the connections and all are OK. I wipe clean all the pipes to see if I can see where the leak is coming from, but noting visable or obvious.
Are there pipes above the axel and if so are they a common place to leak from and if they do need replacing does the rear sub frame need dropping?
Thanks for your help and advice in advance.
Xantia 1.8 estate hydraulic leak!!!!!
citroenxm
- Fallen Hero
- x 70
Re: Xantia 1.8 estate hydraulic leak!!!!!
Hi, yes all the four pipes plus return go up and over the top of the subframe. They useaualy rot just above the frame, in a non viewable place.
As for subframe dropping yes and its NOT Hard at all to drop. You can drop it one side only perfectly well to get a the pipes along the top and examine them. The pipes useually corrode in the pipe clips.
To lower a rear subframe, suppert the car SECURELY under the are of the Cill LIP AND the rear passnger floor, forward of the actual jacking point, this is because the forward subframe bolt is up behind the jacking point.
Remove the rear wheel. Support the frame with a trolly jack under the suspension cylinder area on the frame, undo the front 18mm bolt, and the rear 16mm through the rubber mount, then lower the jack and the subframe will come down with it and reveal the pipes along the top..
BE SURE the car is WELL SUPPORTED.. but try and use both the Cill Lip AND Floor area to spread the cars weight across both areas...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 7164
myc5
If you have a read of this thread you may find some information which could be helpful.
Bear in mind when reading the post that my vehicle is a 1994 1.9td SX, and the "rear plumbing diagram" is for this vehicle. Yours may have a different configuration.
While I never made a visual diagnosis of the leak, I eliminated the possibilities based on where the leak was pouring down the back of the subframe, and was left with brake pipe no9 or the metal return pipe from the height corrector. Replaced the no9 and the leak was gone.
If it turns out to be a front-back pipe, it is possible like I did to renew the failed section of pipe by using a "joiner" .
regards
regards
citroenxm
- Fallen Hero
- x 70
The rear pipeing neaver really changed through the years. The only differences were a switch to anti sink which only added more pipes ON the centre of the subframe area, and hydractive cars are slightly different ON the frame. The actual Front to Rear 4 pipes and return are ALL the same to the SAME places right through production (LX, SX VSX and Exclsuive cars. Not sure about Activas or V6's, but I beleve the V6's are the same too...)
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
myc5
Hey, thanks guys for your kind responses. Could I ask ref dropping the rear sub frame, do i need to remove the exhaust, fuel tank etc as I had to when I had a similar problem with my XM estate? Thanks again.
citroenxm
- Fallen Hero
- x 70
No not at all. ONLY lower down ONE Side and thats the passenger side.. the exhaust will lower with it..
Do NOT remove all four bolts. Theres no need to go in the drivers side.. the fuel tank is well out the way.. also dont lower it too much remember the height selector rod is connected but does NOT need removing. Just lower it enough to see in and check the pipes clearly enough.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
myc5
Thanks very much again.
The pipes in question are they break or suspension pipes and is the a diagram available showning where they go as I think I will replace all four pipes whilst under there!!!
I think I will buy replacement rear sub frame bolts as these look quite rusty.
- x 3306
Dig out the Plus Gas! It does very well in freeing up rusty bolts. ECP do it for £5.50 a can.
- x 7164
myc5
I have pulled this out of the thread I linked to
The "four" pipes run from front to back. If you want to replace all four, without using joiners, then you will have to make the appropriate connections at the front of the car.
a 4.5mm brake supply pipe which splits off at a nearside k-connector to two "Curly" pipes to supply the brakes near and offside. (3.307M originates ABS block)
a 3.5mm return pipe from the height corrector
a 3.5mm suspension supply pipe to the anti-sink valve (3.690M originates..(see service citroen diag))
a 3.5mm pipe which I describe as Brake pipe no9 which terminates at a K-connector at the offside. (3.768 Metres pipe originates from connector at front bulkhead nearside) It appears on the braking system diagram on service citroen, but there was a bit of debate on the thread)
regards
regards
addo
- Sara Watson's Stalker
- x 95
myc5
Wow!!! Thanks
myc5
Just to say a big thank you to everyone who has helped me with their kind and informative advise. Total success after following your fantastic information and advise.
