ENGINE WIRING
canaryman
ENGINE WIRING
Unread post by canaryman »
Hi All,
can any body help me i have a dispatch van and someone has put an engine in it but has not finished the job.
I an trying to get it running but the wiring is a mess i have a thick blue wire with a thickish spade terminal on one end, and there is another a Green with yellow bands on. Can anybody tell me where they go or can sombody send me a wiring diagram for the engine as i am realy stuck.
Mark
Ben82
x 7
Re: ENGINE WIRING
Unread post by Ben82 »
If you could provide the VIN (or last 8 digits of it), along with details of the replacement engine (i.e has it been replaced with an identical engine), can see if I can get anything for you.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Green with yellow bands or dashes is definitely an earth wire; make sure it's a good grounding.
Look on the blue wire to read the three, four or five characters between asterisks that are printed recurringly on the wire.
canaryman
Re: ENGINE WIRING
Hi all
The thick blue wire seems to go upto the fuel pump and when I put
my test light on its live I can not see any numbers on it has anybody got any idears?
Mark
addo
x 95
Peugeot/Citroën wiring isn't colour coded other than for earthing wires. The numbers can be quite faint.
What engine was in it - petrol or diesel, and what size?
canaryman
Re: ENGINE WIRING
Hi
I have got my citroen dispatch 1.9 diesel running its on a p plate
But its running a bit rough ivevgot to set
the tick over as when I take my foot off the throttle
it stops.
THANKS FOR ALL THE HELP
Mark
