Many thanks Martin
Citroen dispatch van radiator fan not working
mitch13
Hi, I'm looking for some information that might help me with an electrical problem I have on my Citroen dispatch van 2000. In brief the radiator cooling fan has stopped working resulting in the van overheating
, so far I have tried: Testing the relays; which are located in fuse box under the bonnet, checking the two fuses in the same location, and I have run power straight to the fan; which seems to be working fine. I have also bridged/shorted the fan switch that is situated near the thermostat and the fan does not work when this is done; which suggests a fuse or relay but I have checked them
Any help would be greatly appreciated.
Many thanks Martin
Many thanks Martin
