Repair for Hateful Xantia Lock Button
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
thorter
x 44
Unread post by thorter »
When the tab on a door lock button broke despite considerable care, I investigated a bodge to jam the two parts back. In my assorted paper clip box, I found item 1, used by scribes and shysters to clip pages of writs together. To experiment, I cut off a length of the strip. It turned out to be thin enough to slide between the button and the inner plastic piece. The material is pretty soft, and I bent up the clip shown in 2 with a view to getting dimensions for a better version in something more springy.
You can see in 3 how it clips on, and it is completely retained when assembled into the main part of the button. When I tried it, it turned out to have just enough spring to work. I fitted it to the car, see 4, and it seems secure. It would be possible to bend it out a bit more with a watchmaker’s screwdriver if you want to be quite sure.
It works just like the original tab, but it is much more straightforward to remove the button when necessary.
Fred
x 8386
Re: Repair for Hateful Xantia Lock Button
Fred, that's excellent!
thorter
x 44
I should have added that the strip is 0.3mm thick and 2.9mm wide (3mm would be fine). I did not measure the final length, but it is less than 20mm. The clip I used has a pointed end, but both ends square would obviously be OK.
Fred
tich731
Unread post by tich731 »
I've only just come across this thread, but have been able to follow the repair for a lock button on my Series II XM.....and it has been a big success.
Thank you Fred. You have saved me about £8.00 for a new button.
2009 C6 2.2 Hdi Exclusive Gris Fulminator
1999 XM 2.0 TCT Balmoral Blue Nacre
1987 2CV6 Rouge Vallelunga
1979 2CV Fourgonette (by Villevans) Cormoran Gris
1981 Midas Silver
1972 D Special Black (gone but not forgotten)
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
Genius!
I'll be using that VERY soon unless anyone has some kicking around and intact?
x 2001
Unread post by Stickyfinger »
Very good.....I will be another one to do this....fantastic !
