I have an issue which might relate to bearings or hub... but I need educated guesses from you gurus!
I have a 2002 phase II Xsara estate (2.0i 16v 136 HP) that has, since I bought it a bit over ½ year ago, a growling sound on the driver's front side and this gets worse when braking, as if strain is being put on the bearings. Also, when driving at low speed there is a low but noticeable whoosh.... whoosh... whoosh sound. I now changed to (wider) summer tires and this got worse (at high speed other noises conceal this). I had changed the brake discs and pads and the problem persists and there is also clearly an intermittent rubbing of the pads on the disc when turning the wheel by hand. Since the discs are new, I'm guessing the hub/bearings must have been damaged on a small accident the previous owner had (which nevertheless made a dent on the rim...). I don't have a tool to check for run out of the hub and I would rather shell out the money on a new hub and bearing. If I can avoid both altogether even better!
Given the symptoms where would your guys point to as the culprit ? I drive less than 10 km a day so this has not bothered me a lot. However, I'm planning to drive with the family from Denmark to Portugal and back (if I don't go insane with the children
Your opinions are, again, highly valued. The trip is planned for 1 month from now and I would like to tackle things in due time.
Best,
Paulo.
