which we ended up fitting a second hand hub that seemed to be ok and got it through the MOT,
flippin things gone loose again, seems to be a common fault on these,
so apart from welding
thanks for that,BX wrote:I am probably wrong but i think there may have been the possibility of 2 different ball joint pins. The pinch bolt as far as I remember is an M10 8.8 bolt. If you want to be able to really welly it up replace it with a 12.9 bolt. They usually come in socket cap format.
