2000 2.0l Hdi Synergie Water Temp Warning Light
ChrisB
New User
Unread post by ChrisB »
Hi
Help please with a water temp warning light which only comes on when the heater is running (stop light doesn't flash). I checked under the car and found water leaking through a chassis rail at the bulkhead, pretty much beneath the heater location. Anyone had a similar problem and is it likely to be heater rad or the pipework to/from it?
If rad, has anyone changed one and how do I go about it?
Also just rebushed the rear beam, bought new flexi brake lines but rounded the nut on the rigid line to the drum (didn't use proper brake spanner) - anyone know where I can get an after market ridgid line (nearside)?
Cheers
2000 2.0l Hdi Synergie - tatty round the edges, but a great mule
Stewart(oily)
x 35
Re: 2000 2.0l Hdi Synergie Water Temp Warning Light
Unread post by Stewart(oily) »
Any half decent motorfactor should be able to make you up a metal brake pipe, as for the leaking heater matrix Citroen recommend Forte stop leak, if you are lucky it might work, if you are losing coolant you need to be very careful.
