Xantia brake pedal mod
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I want to remove the spring bit from my xantia brake pedal, I can feel the plastic plunger bit and wobble it about but dont want to break it, ISTR being told it just pulls out ? anyone done one recently ?
lankytim
Re: Xantia brake pedal mod
Unread post by lankytim »
I did it last week! I needed to pull the brake pedal up as far as it would go then prise the plastic plunger assembly off with a flat bladed screwdriver. It's a bit of a squeeze down there and it's almost impossible to see what's going on but once you get the screwdriver in the right place it should just pop out.
Stewart(oily)
x 35
Thank you, off out to the garage now!
Stewart(oily)
x 35
Easy when you know how :wink:
Much more positive feel now, it may take some getting used to.
