Xsara flashing headlight indicator on dashboard
barneyb32
Unread post by barneyb32 »
I've a xsara HDI and when you're driving in daytime with lights off sometimes the green headlight indicator starts flashing on the dashboard. Turning the lights on and then off sorts the problem but it reoccurs later.
Any ideas?
barney
citroenxm
Fallen Hero
x 70
Re: Xsara flashing headlight indicator on dashboard
Unread post by citroenxm »
The "Alarm" activating, but the sounder switched off???
Im not familliar with the Xsara alarm system, but if its like the Xantia and not reset properly, for example after a battery disconnection, the headlights flash along with the alarm sounder, though a lot of Xantia alarm sounders dont work, or are switched off...
BSI Rest / Battery Disconnect / Reconnect Procedure
A very sad...
1994 XM 2.1 d auto
