help! rough running after timming belt change 2.0 hdi
taffy
Unread post by taffy »
ive changed fuel pump put timming belt on and started her....running like on 3 cylinders and puffin white smoke....have i got a jammed injector?...checked water and oil all good also eml on and have fault codes for fuel pump primary circit...
any help would be great
thanks
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
citroenxm
Fallen Hero
x 70
Re: help! rough running after timming belt change 2.0 hdi
Unread post by citroenxm »
Firstly it wont be a pump timing error as the pumps are not timed at all on the Hdi. Its all done by ecu triggering the injectors in the correct order.
My guess is your cam to crank timing setting is out. Take the engine back to Tdc and try and put your timing pins in the cam sprocket ( at 7 oclock roughly) and in the crank hole behind the starter. Both sbould go in easyilly.
I think you may be a tooth out.
A very sad...
1994 XM 2.1 d auto
taffy
i hope thats all it is :) it runs but not well
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Did you turn the crank backwards at all? :?
x 1049
Unread post by wheeler »
Is the cam pulley the type with the three bolts or the single bolt in the middle ? If its the type with the three bolts did you make sure they were loose when tensioning the belt ? If you don't it can pull the pulley round when tension is applied to the belt & knock it out slightly.
taffy
well took it all apart..timmed it up perfect and yes i left the cam pully bolts loose once i tightened the tensioner....put all bk together and still the same...apart from eml is now off...
whilst taking out the glow plugs i did notice 2 were wet..might have been on compression stroke...
anymore ideas guys?
taffy
this is looking like 1 or 2 injectors i think....
taffy
yes ive turned crank back (wen cam removed)to time engine as belt was off...also cam sensor?how to set?
taffy
well went through elimination process today disconecting the electrical plugs from injectors 1 by 1 and no4 didnnt make a difference so ive taken it out and now need to get another one....are they all the same?
citroenxm
Fallen Hero
x 70
Before buying an injector swap it with the one next to it and see if the fault moves.. if not then the fault is electrical.
Dont worry these systems are not that sensitive you can move them around with no effect..
All 8v 2.0 90bhp and 110bhp ones are the same yes..
A very sad...
1994 XM 2.1 d auto
taffy
yea just tried that and still the same...the end off the injector is like its been polished and no visible holes...like metal fillings from the broke pump have welded it closed...luckly my friend who has the engine i aquired the pump off has injectors....but do they need codeing?
thanks paul :)
citroenxm
Fallen Hero
x 70
Thats what i said taffy.. no theres no codeing lark needed.. plonk in and go...
A very sad...
1994 XM 2.1 d auto
taffy
is it??? ah thank god!! i thought it had to be reduced from 23000psi to 18000psi or something...thanks paul ur a life saver :)
taffy
i will get u some beers when i finallly meet u at a rally mate :)
citroenxm
Fallen Hero
x 70
Now now.. slow downm i might be wrong yet.. but all this injector swapping never caused me any problems.. so lets see if we can sort yours too..
A very sad...
1994 XM 2.1 d auto
