c3 Sensodrive snowflake
gowza
New User
Unread post by gowza »
My 2004 c3 1.4 sensodrive has got the dreaded snowflake.
Local Citroen garage have said fault code is around the actuator and wiring harness but that the gearbox also sounds very noisy.
They say £3000 for new gearbox, actuators etc and that it is not economical to fix.
Also say exhaust will need replacing soon.
80,000 on the clock so not that many miles, well in my mind
In the 9 years I've had it the following has been repaired
Gear box software updated 2, once when it wouldn't go in reverse
New head gasket
Both headlights replaced due to water ingress/delimitation
New starter motor
new battery
Front brakes and pads done twice
Front drop bars
3 sets of tyres
New windscreen
4 sets of new headlight bulbs
New cam belt.
Air con stepper motor
New temperature sensor, dash only show 1 or 2 temperature lights and has for the last 3 year, garage said was working ok.
Normal wear and servicing, oil, filters etc
Annoyingly the front disks/pads and front tyres were only fitted 3 months ago :cry:
Would I buy another Citroen, unlikely. Need to go back to having a job were I get a company car. :-D
Lighty
x 35
Re: c3 Sensodrive snowflake
Unread post by Lighty »
All of that sounds like normal maintenance for a C3, these cars can be repaired for a lot less if you go about it in the correct way.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
SwissSPEC
Unread post by SwissSPEC »
Get a 2nd hand gearbox instead?
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Lighty
x 35
The gearbox is not the problem, bearings can be replaced quite cheaply, it's the gear change actuator that is costly , in fact most of the automated bits are lots of money, but these can be sourced second hand.
Trouble is you need a good knowledge of how it works to correctly diagnose the fault.
Citroen C15
Citroen Ami
x 1240
Unread post by Peter.N. »
Don't get an auto next time unless you can't do without one, manual gearboxes usually last the life of the car and are more economical, even if you have to replace the clutch its a much easier job and cheaper than an autobox.
Peter.
Lighty
x 35
The gearbox he has is a manual, it's just automatically controlled,
Citroen C15
Citroen Ami
