Firstly, I would like to say thank you for all the help I have had with my previous posts.
Great forum with helpful people.
I am trying to identify which plug I should use for my Citroen XM 2.0 Turbo Automatic 1995.
I have been informed that for models up to 7/95 it is a Champion RC7BMC and for models from 8/95 it is Champion RC8DMC.
The earlier model has the lesser horse power 2.0 Turbo engine.
My car is registered 2/95, but it is a Mark 2 XM.
I thought the Mark 2 Citroen would have come with the higher horse power engine but it doesn't appear to be the case, if the above recommendations are correct.
The reason for all this concern?
My car is pinking and I suspect I have been advised wrongly by a local car parts shop as to which plugs I should use (In this case - Bosch Super FR7 DC9)
Yes I know, maybe I should have gone to Citroen in the first place but I would still be interested in your comments.
Thank you.
AndUK
Which Spark Plug for an XM ?
If you have your XM owner's brieflet manual - you'll find the correct type plugs listed here. Citroen specifies Eyquem plugs - which are widely availabe and known to be a no-problem part.
Bosch plugs are branded quality plugs - but it can be a nuisance to find the correct type if the engine is not OEM specified for these.
